Tailmessage not working in ASL3
Great!
sudo asl-repo-switch -l main
sudo apt update
If we don't hear of any new issues, the packages will be likely be promoted sometime next week.
Sorry for the delay. I tested on my prod VM and its progress. It seems like the tailmessage is now playing. :slight_smile: However, it also seems like the tailmessagetime=120000 is not working. The tail message plays, but only when the node ID’s, which is set to every 10 minutes, not the 2 minutes I have set for testing. This is fine, since I was going to set it to 10 minutes anyway. Its odd because the 2 minutes worked on the test VM. I’m not sure why the same isn’t working on my prod VM when the only difference is the test VM is Debian 13 and prod is still Debian 12.
I’m going to mark this as solved. Thanks for everyone’s help with this. I’ll keep my server on the beta until the next update, then switch it back to main.
73,
Larry, N6LKA
@N6LKA If this is the solution would mind marking it a such? That helps future troubleshooters solve their problem or move on.
Edit: Not sure what happened there. Immediately after I posted this the solution showed up. I thought I'd missed the solution and marked my message for deletion which caused the solution to disappear.
Hey Tim,
Not sure what happend. I had already marked the post as a solution, but when I just now came back, I see it wasn’t marked anymore. I re-marked it post as the solution.
