A few nice simple tables showing by the number of private/invalid nodes reporting telemetry to the stats server at https://stats.allstarlink.org. This data only cover the last 5 minutes. Longer time spans create larger tables.
Count is the number of times the IP listed has reported telemetry for the invalid node to the stats server. The version of the client reported is also listed as an additional reference/data point.
If your IP address is showing up here then please fix your node config and comment out the statpost_url line for any node with a number below 2000 or generally outside the normal node number allocations.
