Seems it works a bit better… I came from Hamvoip back to DIAL.
On Feb 22, 2018 11:52, “Joe Moskalski” [email protected] wrote:
Hamvoip
[email protected]
On Feb 22, 2018 11:48 AM, “Sam Nabkey” [email protected] wrote:
DIAL or Hamvoip?
[email protected]
On Feb 22, 2018 10:52, “Joe Moskalski” [email protected] wrote:
I do not think server horsepower is the issue. I am running three TX/RX simulcast sites off of a Pi3 and when I look at the system resources used it isn’t working very hard.
[email protected]
On Thu, Feb 22, 2018 at 10:47 AM, Jesse Lloyd [email protected] wrote:
I should add to my last post that I use a dual NIC server. One RTCM is connected directly to the server to provide timing only. The other NIC ties to the network with the other RTCM’s that have radios attached.
Cheers,
Jesse
On Feb 22, 2018, at 6:43 AM, ARS W5OMR [email protected] wrote:
That’s probably a latency in the audio section of the PC being used.
A buddy had the same issues while operating his HF station, remote. After a few minutes, the latency grew and grew… He used WWV (he lives in West Central OK) as a time base…
His solution was to get a more “robust” (read: Turtle Beach) sound card. This was in his desktop at the house.
It might not be a software problem, as much as a Hardware issue.
I don’t remember if you said this was on an RTCM or not but I know one is involved.
I believe I would check more on all audio devices involved.
[email protected]
[email protected]
On Feb 22, 2018 12:11 AM, “Hayden Honeywood” [email protected] wrote:
[email protected]
I’ve made a YouTube video with clips from a single conversation I had this morning on the repeater. The audio was recorded on my dashcam.
As can be heard in the video, when I start the conversation, the audio delay is nil, or very little when unkeying. However, by the time I’m finished (I think the conversation lasted about 20 minutes) the audio delay is out to 4 or 5 words!
We were both using the same repeater. We have a repeater linked in from another location. I’ve noticed when talking to someone via that method, the audio delay issue does not build up so quickly.
Hopefully this explains a bit better the issue I’m having.
https://youtu.be/KG3GgaHVWbI
Regards
Hayden VK7HH
