Having difficulty with one of RTCMs connecting and I was wondering if there is logging in asterisks of the RTCMs that are connected or a way to display the connections in allmon?
Thanks and 73
Ted
W6SAT
Thanks and 73
Ted
W6SAT
Ok, after much experimentation I figured out why I could not get the RTCM to connect. I had RTCM menu item 8 set to 1 and menu item 10 set to 0. For some reason this was keeping the RTCM from connecting to the allstar server.
Any thoughts on this would be appreciated.
W6SAT
Is there a GPS connected to this RTCM? If not, 10 should be 2 indicating that no GPS is connected. You only need a GPS for voting applications.
With 10 set to something other than 2 the RTCM is expecting a data stream from the GPS to time stamp each packet. Furthermore, with no master clock (a RTCM with a GPS) at the server, chan_voter would not accept packets with a time stamp anyway.
Thanks Tim
Ted
W6SAT
