Severe : Could not contact the Allmon3 Manager
You have a configuration error most likely. Since this is Debian 10 (which is unfortunate) there is no asyncio.exceptions exception type so it doesn’t get handled cleanly. You need more of the log from /var/log/daemon.log. The log output from systemctl isn’t useful in these cases because it truncates stuff.
You really should run this in the foreground as allmon3 --debug until you actually have a working configuration.
Well is there a Debian 11 version of Allstarlink I can Use ?..
Sign me Up… as the Ver 2 I use must be Debian 10
/var/log/daemon.log doesn’t Exist in my setup
sudo allmon3 --debug
DEBUG: (allmon3) config file is /etc/allmon3/allmon3.ini
DEBUG: (asl_allmon.node_configs) nodes_on_host: 1
DEBUG: (allmon3) web config file is /etc/allmon3/web.ini
INFO: (allmon3) no %s found; no menu data available
DEBUG: (allmon3) user_table file is /etc/allmon3/users
DEBUG: (asl_allmon.security) loaded 1 entries from /etc/allmon3/users
DEBUG: (asl_allmon.node_db) entering get_allmon_db()
INFO: (asl_allmon.node_db) Retrieving database from http://allmondb.allstarlink.org/
INFO: (asl_allmon.node_db) Updated node database in 0.92 seconds
DEBUG: (asl_allmon.node_db) exiting getAllMonDB()
DEBUG: (asl_allmon.node_db) entering set_my_info()
DEBUG: (asl_allmon.node_db) exiting set_my_info()
DEBUG: (allmon3) starting the main work loop
DEBUG: (allmon3) enter start_tasks()
INFO: (allmon3) starting status ws [email protected] on port 16700
INFO: (allmon3) starting cmd ws [email protected] on port 16701
INFO: (allmon3) starting allmon3 master ws on port 16080
INFO: (allmon3) starting node_db updater
DEBUG: (asl_allmon.allmon3_ws_status) enter node_status_main(1200)
DEBUG: (asl_allmon.ami_conn) asl_create_connection(failhard=True)
DEBUG: (asl_allmon.ami_conn) connect() using 127.0.0.1:5038
DEBUG: (asl_allmon.ami_conn) AIM version: Asterisk Call Manager/1.0
DEBUG: (asl_allmon.ami_conn) enter asl_cmd_response()
DEBUG: (asl_allmon.ami_conn) command >> ACTION: LOGIN USERNAME: admin SECRET: usgmrs EVENTS: 0 ActionID: 4db960a4-d0f1-41b0-8c2b-a44bb83c3622
DEBUG: (asl_allmon.ami_conn) response >> Response: Success ActionID: 4db960a4-d0f1-41b0-8c2b-a44bb83c3622 Message: Authentication accepted
DEBUG: (asl_allmon.ami_conn) Response: Success ActionID: 4db960a4-d0f1-41b0-8c2b-a44bb83c3622 Message: Authentication accepted
DEBUG: (asl_allmon.ami_conn) leaving asl_create_connection()
INFO: (asl_allmon.allmon3_ws_status) server listening on 0.0.0.0:16700
INFO: (asl_allmon.allmon3_ws_status) server listening on [::]:16700
INFO: (asl_allmon.allmon3_ws_status) broadcasting status for 1200 on port 16700
DEBUG: (asl_allmon.allmon3_ws_status) enter node_status_broadcast()
DEBUG: (asl_allmon.allmon3_ws_status) Node 1200: status_connections: 0
DEBUG: (asl_allmon.allmon3_ws_status) status asyncio.sleep(1)
INFO: (asl_allmon.allmon3_ws_cmd) server listening on 0.0.0.0:16701
INFO: (asl_allmon.allmon3_ws_cmd) server listening on [::]:16701
DEBUG: (allmon3) finally of start_tasks()
DEBUG: (allmon3) main finally
Traceback (most recent call last):
File “/usr/bin/allmon3”, line 95, in start_tasks
await asyncio.gather(*tasks)
File “/usr/lib/python3/dist-packages/asl_allmon/allmon3_server/init.py”, line 254, in main
await site.start()
File “/usr/local/lib/python3.7/dist-packages/aiohttp/web_runner.py”, line 128, in start
reuse_port=self._reuse_port,
File “/usr/lib/python3.7/asyncio/base_events.py”, line 1378, in create_server
% (sa, err.strerror.lower())) from None
OSError: [Errno 99] error while attempting to bind on address (‘::1’, 16080, 0, 0): cannot assign requested address
During handling of the above exception, another exception occurred:
File “/usr/bin/allmon3”, line 208, in
asyncio.run(start_tasks())
File “/usr/lib/python3.7/asyncio/runners.py”, line 43, in run
return loop.run_until_complete(main)
File “/usr/lib/python3.7/asyncio/base_events.py”, line 584, in run_until_complete
return future.result()
File “/usr/bin/allmon3”, line 97, in start_tasks
except asyncio.exceptions.CancelledError as e:
AttributeError: module ‘asyncio’ has no attribute ‘exceptions’
Ok. That’s a bug. Your node doesn’t have IPv6 but it’s trying to bind to it. I will have to look into that.
Ahh Ok glad to be of help I guess …
Lol
Rob…
Will you please paste in the output of ip addr show from your system?
oot@1200Node:/home/repeater# ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: ens18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether aa:7a:9b:40:21:fe brd ff:ff:ff:ff:ff:ff
inet 192.168.1.185/24 brd 192.168.1.255 scope global dynamic ens18
valid_lft 46680sec preferred_lft 46680sec
Thanks. What’s the contents of your /etc/hosts file? And did you say this is an ASL2 image?
Yes it is the ASL2 Image
Contents of /etc/hosts
127.0.0.1 localhost
127.0.0.1 1200 Node.NOT SET 1200 Node
The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
Well, there’s why interesting. Delete the line with ::1 and it should start. But if that’s a default thing in ASL2 that’s a problem. It looks like maybe it’s a half-set-up IPv6 network.
Yes that loaded it…
Thanks so Much…
I’m not aware of any PC based Allstar Images other than ASL but if you happen to know any please let me know. and I will have no problems in giving it a try.
I am going to image this OS so in the Future I can resume where this one left off…
Again thanks
Rob…
This is a /etc/hosts on another image using i think asl 1
Standard host addresses
127.0.0.1 localhost
This host address
127.0.1.1 vaio-hp15notebookpc
Now I have to do some reading about linking my Nodes onto the allmon3 page like they do on allmon2.
But Progress at least.
Now the Learning Begins.
Rob…
So just as a PSA, for people who find this later on… deleting the ::1 entry from /etc/hosts is NOT THE RIGHT FIX long-term. The address ::1 is the IPv6 equivalent of 127.0.0.1 from IPv4. In this particular case, when localhost is being resolved, the system believes IPv6 to be enabled however the network configuration is not enabling the address ::1 at boot.
A correctly configured network stack (and this is definitely the default) should look like this for the localhost adapter:
$ ip addr show dev lo
    inet6 ::1/128 scope host
Note there is both a 127.0.0.1 and ::1 address. This has been the standard Linux configuration for a decade or more. If the system in question as IPv6 enabled + /etc/hosts points localhost to ::1 + missing ::1 address in combination, then any application that is IPv6 aware will have operational problems.
I will develop a code adjustment in allmon3 for this condition.
