Hi,
I’d like to create an Rx only SIP Dial In service for my node, with no DTMF / VOX control.
Whats the best way to go about this? I have successfully setup a dial plan so callers via SIP are connected via the node but I need to disable the control side of things.
I tried creating a dummy node with the DTMF functions stanza empty, but then I can’t use the Macro to connect to the “master” node.
Is there a neat way of doing this?
thanks
