Now I need to struggle with getting the SimpleUSB stuff going. I’ve enabled and selected as per the docs in modules.conf and rpt.conf but when I try to run the SimpleUSB stuff in asl-menu, it complains about needing to enable and select as above. And yes, I’ve rebooted since the edit…
I’m curious as to why the asl-menu selection doesn’t seem to pick up that the SimpleUSB option is both loaded and selected? Is this a known bug? Does asl-menu have a config file where the correct path needs to be set?
As I said, the documention for Allstar is quite poor it seems
Now that I have things running under Debian 9 (and its older kernel), I’d really like to upgrade to Debian Buster in order to keep some other things running on the same Pi3 happy.
I tried your idea of dpkg asl-dahdi-linux-dkmsbut apparently something is missing:
root@Wilsonville:~# dpkg asl-dahdi-linux-dkms
dpkg: error: need an action option
Type dpkg --help for help about installing and deinstalling packages [*];
Use ‘apt’ or ‘aptitude’ for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through ‘less’ or ‘more’ !
Curiouser and curiouser
root@Wilsonville:~# dpkg-reconfigure asl-dahdi-linux-dkms
/usr/sbin/dpkg-reconfigure: asl-dahdi-linux-dkms is broken or not fully installed
root@Wilsonville:~# ^C
