New to AllStarLink.
Fresh install using a pi-3+ and Model RA-40 interface. Repeater Motorola XPR-8300
When I receive a signal on the repeater and shows via a green light that a signal is present an at my interface board I see the COS present. at D1 at CM119A U1 Chip the pull down is present. No signal is 4.0 volts, with signal 0.0 volts which tell me that my COS circuit is working.
I did follow the instructions on setting up an AllStarLink node.
Also I did run the “simpleusb-tune-menu” to check my transmitter for keying audio which if fine…
Dale KJ6IX
