Hello everyone I’m running the new version ASL_Images_Beta 4 together with a usb key with the cm108 and a raspberry3, because since I finish speaking the radio remains in the carrier for about 10 seconds in the configuration rxondelay = 0 and rxaudiodelay = 0 are inserted. I can’t understand where I went wrong, any clarification will please me
Special thanks to all the developers and the group for their commitment
Hello in0ndt,
Be sure to set duplex=0
for no hangtime or duplex=1
if you want courtesy tones. In the case of duplex=1
be sure to set hangtime=xxx
to a short value.
These settings are in the /etc/asterisk/rpt.conf file. Be sure to restart asterisk after making changes. Let us know if you need help with any of that.
Second this. The default hangtimes are pretty long because they’re meant for a repeater and not a simplex node. Set hangtime = 0 and althangtime = 0
You guys are big … I have been banging my head for a week I downloaded all the versions I also tried with a pi4 I saw everything but I did not see inside the rtp.conf file I thought that the parameter was not there in rpt.conf but it was inside the usbradio.conf and simpleusb.conf … what about thanks
I think the simpleusb.conf has its own delays. rxondelay and rxaudiodelay. I have both set to 0 on my simplex node.
Did those hang times work for you then?
Rob … rxondelay and rxaudiodelay. by default they are higher. I brought them to 0 but I had not yet tried with the values of hangtime = 0 and althangtime = 0 To do the tests I enabled all the rx files both usbradio and simpleusb because the two values are in the two files. Then as I put as you suggested the hangtime and althangtime value of 0 in Rpt.conf I restarted asterisk and everything went as I wanted.
Perfect! I had the same issue the other day. I’ll be lowering the default hangtime in the config and adding a commented out line with higher hangtime for repeaters.
