Procedure for loading DIAL on a R-Pi2 or a PC
This topic I find very interesting and would like to be included in any further developments. I want to implement DMR on the allstar network. I have access to the DMR-MARC network but it’s pretty closed.
I want my network to be open and people can all talk using the mode of their choice.
I thought a PI with a DMR portable would make a nice portable node. Also being able to deploy a DMR repeater is a must too. The goal is getting it to sound as good as possible and be on allstar!
N1XBM
Apparare Scientor
Paratus Communicare
Allstar Node # 27086, 41540, 41812, 42086
Last comment on this since it is off topic for this group (but I would love to continue it on a side channel).
When we played with this type of thing we used the DV3000 and a custom version of the DSD code. I grabbed audio off of the discriminator of the radio (or from an RTL dongle), piped it into DSD, took the AMBE frames from the decoder and fed them to the DV3000. PCM was then fed to Allstar through the USRP channel driver. This gave me DMR and DStar (P25 P2 was never tested) decode directly into a test system from the RF side. Today, I would use MMDVM rather then DSD as it implements a much better radio interface and digital path.
Mike
On Thu, Oct 29, 2015 at 9:42 AM, Bryan Fields Bryan@bryanfields.net wrote:
On 10/29/15 9:33 AM, Mike Zingman wrote:
The MBE (mbelib) code you are thinking about is both patent encumbered at this
point and only decodes AMBE frames. It does not implement the encoder. I
have extensive experience with that code base and the audio quality as
compared to the chipset is not acceptable. It is good for experimentation,
but I would never deploy a solution with it.
Also in typical ham radio fashion they pissed off the original developer by
taking his code and making it closed source.
Bruce Perens K6BP is working on some legal stuff regarding the AMBE patents,
but that’s still a while out. What I’d suggest is to use the TIA standards
document and then base it off that, host it in a foreign country and make a
script that pulls it in at compile time if the user wants it.
Frankly, I’d like to see the same thing for the IRLP channel driver. Pulling
that just cuz Dave got his panties in a bunch is caving to bullies.
There is a channel driver for dstar that uses a dongle, written by KI4LKF.
http://zipwww.com/a/rtpdir.weebly.com/chan_dstar.zip/chan_dstar.c.html
I’ve messed with it once, it was not ready for prime time IMO, but then again
there is lots of stuff we runs that’s not exactly stable either.
73’s
Bryan Fields
727-409-1194 - Voice
727-214-2508 - Fax
http://bryanfields.net
This topic could be another e-mail list. This is where allstar has it nailed being able to link multiple audio paths. We have someone using dstar on our system it sounds pretty decent. I’d like to see p25 and DMR included. I’ll stop posting on this as well and keep it last for this list.
N1XBM
Apparare Scientor
Paratus Communicare
Yes! I ran it that way with an r100 for a few weeks before moving it over to the msf5000. I had no issues running simpleusb and usbradio. I don't have any of the cracks or pops anywhere that you are referring to running usbradio. I do know what you are talking about but I have never experienced that on any of my equipment.
Sent from my iPhone
On Oct 29, 2015, at 10:14 AM, David McGough <kb4fxc@inttek.net> wrote:
Has anyone tested the simpleusb driver with the RPi2 version of DIAL?
On Thu, 29 Oct 2015, Corey Dean wrote:
I thought I had replied to everyone and I noticed I only replied to Neil. I have been running the Debian rpi2 image for quite a while. Way back when Steve first created it. I run it in full duplex mode using usbradio on an msf5000 with no issues at all.
I know what you are talking about with the echo issue. That seems to just be a problem on the arch image on the hamvoip site as that is the only place I have heard it. I did try that image long and and having audio delays at almost 10 seconds and time just made it unusable. That was even using simpleusb. No problems running usbradio and dsp on the Debian image.
To make a long story short, the Debian image just works! No have had zero issues with it.
Corey N3FE
Sent from my iPhone
On Oct 29, 2015, at 8:46 AM, Jon Rorke <jrorke@cogeco.ca> wrote:
I have been playing with the full duplex mode using DSP decode (PL, carrier squelch) in and out on the RPI2 with DIAL and so far it seems to be on par with what Acid does on a PC.
There is some latency due to audio processing but its about 200 to 250 ms and seems to be stable. I have never seen an acid box with 0 latency on the full duplex audio.
In may opinion it woks just as well as an ACID set up on a pc for a single full duplex repeater node.
Can;t speak to the other questions though.
Jon VA3RQ
On 10/28/2015 5:48 PM, Neil k8it wrote:
I have been waiting a bit before I start playing with DIAL on a RPI2.
I still have two questions
1. Does the RPI2 DIAL version solve the tx echo buffer issue that the current version of Asterisk RPI2 code has. The fix to this issue seems to be taking a long time.
2. Some users have reorted that a lot of modules have been disabled, such as the Echolink channel driver and others.
3. With the new Mini-DV4 dongle $125 and the amount of capability, has anybody wrote a channel driver to tie the Yaesu Fusion Wires-X network into DIAL. It appears that most of the documentation is out there, we just need someone to write the channel driver
73 Neil Sablatzky K8IT
Allstar Node 41838 KITLINK
Allstar Node 42087 KITLINK HUB
IRLP Node exp0068
Echolink K8IT-L
WIRES-X K8IT 11479 Room 21479
Sent: Tuesday, October 27, 2015 10:35 AM
To: N7MTC . ; app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Procedure for loading DIAL on a R-Pi2 or a PC
Mac,
The RPi2 install is pretty much download the image, burn it to SD card,.
Once the Pi boots, you can login on the HDMI / USB console, or SSH into the board on port 222.
The board is setup for DHCP so check your DHCP (router) server for address.
If you want, you can login via the built in serial port at 115,200
System will walk you through setup.
FAQ for DIAL is at:
<AllStarLink Wiki;
73, Steve N4IRS
On 10/27/2015 10:20 AM, N7MTC . wrote:
Is there a procedure for loading the "new" DIAL version of asterisk for Raspberry pi2?
I am looking to connect either a Pi2 or an intel NUC to a Yaesu Dr-1x using the Arcom RC-210 and the Arcom ADR. I noticed DIAL has replaced ACID as the latest flavor of asterisk for both PC and PI2. I have not found any install write-ups or YouTubes showing a DIAL install.
Regardless of which platform I will need to use an USB to Serial adapter to connect the ALLSTAR node to the repeater controller. It will be of the FTDI chipset either a trendnet Tu-s9 or a GearMo USB RS-232.
/73
Mac, N7MTC
Benjamin Franklin - "Those who surrender freedom for security will not have, nor do they deserve, either one."
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2015.0.6173 / Virus Database: 4455/10900 - Release Date: 10/27/15
Why?
system it sounds pretty decent. I'd like to see p25 and DMR included. I'll
I would like to see asterisk being the common platform used for internet
linking of any radio systems. It decouples the network from the technology.
Course this does remove the network operators from the god like status they
have and the ensuing circle-jerk :slight_smile:
On 10/29/15 11:25 AM, Robert Newberry wrote:
Bryan Fields
727-214-2508 - Fax
I have a considerable investment into Fusion. I will support this effort in any way I can. I ordered one of the dongles that does Fusion, Dstar and DMR. I saw the YouTube video of the demonstration about this dongle in the Fusion mode.
I see alot of potential here in this group
Ron
N6GKJ
On Oct 29, 2015 6:47 AM, “Steve N4IRS” szingman@msgstor.com wrote:
When we did the DMR to AllStar testing, we used the NW Digital Radio DV3000. It was mounted on a RPi2 running asterisk.
The DV3000 uses AMBE-3000 vocoder chip from DVSI. We tested with Mototrbo and D-Star. Did not have a Fusion or P25 radios.
73, Steve N4IRS
On 10/29/2015 8:03 AM, David McGough wrote:
Guys,
I haven’t looked carefully as to which variants of AMBE are in use by
D-STAR, Fusion, etc…Doesn’t the original AMBE patent expire fairly soon?
The reason I’m asking is that I know there are some fledgling open-source
AMBE implementations out there. A couple years ago I hacked CODEC2 into
Asterisk for experimentation, thinking about directly linking to HF via
the FreeDV project–and, not wanting to transcode from one low-bandwidth
CODEC to another, making truly awful audio!
After playing with it a few weeks, I didn’t do much more…(I’ve still
got that code and it still works, if anyone wants to play with it?)
…Just wondering.
73, David KB4FXC
On Thu, 29 Oct 2015, Matthew Pitts wrote:
Mike,
You are correct in the statement that the DV4mini needs additional
hardware to handle the transcoding from a digital radio. Once I get my
nodes back up on my Raspberry Pi, I will work on an updated version of
the D-STAR channel driver that supports DMR and Fusion AMBE encoding and
decoding as well as radio control functionality for the DV4mini.
Matthew Pitts
N8OHU
On October 28, 2015 6:18:34 PM EDT, Mike Zingman mike.zingman@gmail.com wrote:
Actually the DV4Mini alone does not help tie Allstar into Wires-X. In
order to do that one must:
  1. Have an interface to the YSF network protocol
  2. Decode and extract the AMBE frames from the streamed protocol
  3. Transcode the frames to PCM at the proper sample rate using the DVSI
AMBE3000 chipset
  1. Send those frames to something like the already created USRP channel
driver
In reverse, 4, 3, 2, 1 to send data back to the YSF network. In
addition
to the simple outline above, you would want to
a) Add audio filtering/shaping to make the AMBE audio more acceptable
to
what we are used to on Allstar (one of the single greatest aspects of
Allstar is the audio quality)
b) Transfer of as much metadata between the networks as possible
The DV4Mini is a radio module + digital modulator (DStar/DMR/YSF). It
has
no AMBE encode/decode hardware so there is no way to transcode the
audio
content. For that a “ThumbDV” or a DV3000 would be the hardware of
choice. The DV4Mini could be used as a user radio on an existing RF
network, but one would still need the AMBE3K to do the transcode.
Mike
    the
    seems to
    such
    has
    network into
    need
IRLP Node exp0068
Echolink K8IT-L
To: N7MTC . n7mtc@outlook.com ; app_rpt-users@ohnosec.org
or a
PC
Mac,
card,.
into
address.
FAQ for DIAL is at:
<http://docs.allstarlink.org/drupal/node/170>
<http://docs.allstarlink.org/drupal/node/170%3E>
73, Steve N4IRS
Is there a procedure for loading the “new” DIAL version of asterisk
for
Raspberry pi2?
replaced
not
adapter
of
/73
Mac, N7MTC
Benjamin Franklin - “Those who surrender freedom for security will
not
have, nor do they deserve, either one.”
App_rpt-users mailing
listApp_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
confirmation. If you have trouble unsubscribing, please send a message
to the list detailing the problem.
down
message to
10/27/15
down
message to
