# Problem setting up Iphone connection
**URL:** <https://community.allstarlink.org/t/problem-setting-up-iphone-connection/15639>\
**Category:** AllStarLink\
**Created:** [October 21, 2019, 9:16pm UTC](https://community.allstarlink.org/t/problem-setting-up-iphone-connection/15639 "2019-10-21T21:16:39Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![WD6AWP](https://community.allstarlink.org/user_avatar/community.allstarlink.org/wd6awp/32/5_2.png) [@WD6AWP](https://community.allstarlink.org/u/WD6AWP)\
**Post date:** [October 22, 2019, 1:07pm UTC](https://community.allstarlink.org/t/problem-setting-up-iphone-connection/15639/2 "2019-10-22T13:07:18Z")
</div>
Is the new node on a new server, or on the same server? These setup instructions allow a call to any node on the server.
> [@Zoiper Setup for AllStar](https://community.allstarlink.org/t/zoiper-setup-for-allstar/14893):
> Zoiper is an iOS and Android VoIP telephone app that can be used with AllStar. AllStar Node Settings The Zoiper configuration below allows connections to any node on your AllStar server. In /etc/asterisk/custom/iax.conf add the following lines. This sets the user ID to zoiper and password to the password of your choice. Any number of users can use this ID at the same time. ; Login for zoiper [zoiper] username=Users type=friend context=zoiper host=dynamic auth=md5 secret=yourZoiperPassword di…
_[View the full topic](https://community.allstarlink.org/t/problem-setting-up-iphone-connection/15639)._
