Private ID's in RPT.conf
Hello all,
It has been years since I have posted here. You would think that I would know the answer to this question as I have many nodes and playing with this since 2010...
I have a special project I am working on, I will need to add at least 20 private nodes to my server. That is a lot of cut and paste operations and will create a huge rpt.conf file. Just how much of the node information is really needed, there will be no telemetry, no callsign id, no radio all psuedo nodes.
I have written a client app that will run on the Allstar Server and I will talk to that client with a Dispatch Console I have written. The console works great tied to a radio, so all the transport stream path ways work perfectly. The client will translate what the console sends into what Allstar expects. Have not worked out the bugs yet but getting there. I do not want to replicate all the info if I can avoid it. Any thoughts or comments would be greatly appreciated. Once this thing is up and running I will post a YouTube video...
73,
Ron, N4RLS
Not much copy/paste is needed, and your rpt.conf does not need to be big. You only need to have settings defined once in a template, and then reuse that template for each node definition.
I have cut and pasted as many as 8 nodes on a server and the file was huge, my question is how much is really needed? 95% of the information will all be the same
Thank you,
Ron, N4RLS
On Sun, Oct 25, 2026, 12:06 Mason Nelson <[email protected]> wrote:
Someone replied to your post.
| N5LSN
October 25 |
Not much copy/paste is needed, and your `rpt.conf" does not need to be big. You only need to have settings defined once in a template, and then reuse that template for each node definition.
allstarlink.github.io
Asterisk Templates - AllStarLink Manual
AllStarLink Manual
Then 95% of the information does not need to be repeated.
Did you click the link I included above...?
Every node tagged with (node-main) inherits all the template settings. Settings changed in the node-specific stanza will override the same settings in the [node-main] template. As you will see, adding a new node requires the addition of just a few lines.
I missed that link, ASL3 has really changed things. I am running ASL2 on all my nodes, guess its time for an upgrade
| N5LSN
October 25 |
