I didn't think it would. Thank you
The only mention of power in the file is power management disabled.
can you share how your asl nodes are configured? such as are you using simpleusb one one and not the other?
I just used the asl-menu option. Set one for simpleusb and one on usbradio and it worked. Had 2 public nodes. My SD card failed so had to do a complete reload but I did update and did an online backup. It didnt restore both node numbers only the main one but I just chalked that up to I loaded the wrong one. Which is entirely possible. Yes I did have to setup all my allscan, supermon, and other things but doing it that way kept it fresh in my mind. Almost like it took me back to school lol.
I'm using a repeater on one node and a simplex radio as a link to another repeater. Will both of your radios transmit simultaneously without issue?
Well, I am sorry I did not check other posts of yours. I did not see it in this post, which is where I was looking for it.
They did yes. I havenāt had them both setup in some time. Only the one.
are you able to retrieve the simpleusb and usbradio parameters that you used and share those with me?
currently, my repeater is active as simpleusb and the link is active as usbradio. mainly because the repeater was setup first and it is working well that way. should I switch roles?
ok. got both radios hooked up to the server. both keying simultaneously, but one muted. compared a dmesg immediately before and after the alteration. no difference in reports.
I finally got it all working. Strangely, i am running both nodes, both the repeater and the link radio on simpleusb. They're was no need to use usbradio for one and simple usb for the other. It's working great now.
That's good news. Did you have to do anything special for your setup?
