I couldn’t post the whole rpt file it was too large.
try this (good for 1day):
https://ctxt.io/2/AABQ6cwuFQ
i can’t connect 1998 to 48168 via the client see output:
ip-172-31-27-215*CLI> rpt fun 1998 *348168
Node Variable dump for node 1998:
RPT_AUTOPATCHUP=1
RPT_NUMLINKS=0
RPT_LINKS=0
RPT_NUMALINKS=0
RPT_ALINKS=0
RPT_ETXKEYED=0
RPT_TXKEYED=0
RPT_RXKEYED=0
-- 8 variables
[Sep 22 11:58:49] WARNING[31817]: app_rpt.c:11125 rpt_call: Cannot start dialtone
-- Hungup 'DAHDI/pseudo-1333046646'
-- Hungup 'DAHDI/pseudo-486171386'
RPT_AUTOPATCHUP=0
RPT_NUMLINKS=0
RPT_LINKS=0
RPT_NUMALINKS=0
RPT_ALINKS=0
RPT_ETXKEYED=0
RPT_TXKEYED=0
RPT_RXKEYED=0
-- 8 variables
That makes no sense. Did you or your node provider change your codes? Where did you get this node?
A normal node would have in your [1998]
stanza there should be a functions = functions ; Repeater Function stanza
setting.
Then the functions stanza should have
;;;;;; Mandatory Command Codes ;;;;;
1 = ilink,1 ; Disconnect specified link
2 = ilink,2 ; Connect specified link -- monitor only
3 = ilink,3 ; Connect specified link -- tranceive
4 = ilink,4 ; Enter command mode on specified link
70 = ilink,5 ; System status
99 = cop,6 ; PTT (phone mode only)
I agree with wd6awp. There is a lot of stuff missing in different parts of your rpt. There is a function stanza but it is not referenced in node 1998. Also the permalink is *813.
Somebody has reworked and edited the rpt and has it way off.
Not that I’m aware of. Other than this node being created back in 2018 and is ASL 1.01 I didn’t think I changed anything from the default other than what was necessary for customization.
Is there a default rpt.conf I can download and let me run beyond compare and see what’s up or maybe just start over?
i did use this template for creating private nodes:
https://dvswitch.groups.io/g/allstarlink/wiki/9671
[1999]
rxchannel = USRP/127.0.0.1:34001:32001 ; Use the USRP channel driver. Must be enabled in modules.conf
; 127.0.0.1 = IP of the target application
; 34001 = UDP port the target application is listening on
; 32001 = UDP port ASL is listening on
duplex = 0 ; 0 = Half duplex with no telemetry tones or hang time. Ah, but Allison STILL talks!
hangtime = 0 ; squelch tail hang time 0
althangtime = 0 ; longer squelch tail hang time 0
holdofftelem = 1 ; Hold off all telemetry when signal is present on receiver or from connected nodes
; except when an ID needs to be done and there is a signal coming from a connected node.
telemdefault = 0 ; 0 = telemetry output off. Don't send Allison to DMR !!!!!!!!!!!!!!!!! Trust me.
telemdynamic = 0 ; 0 = disallow users to change the local telemetry setting with a COP command,
linktolink = no ; disables forcing physical half-duplex operation of main repeater while
; still keeping half-duplex semantics (optional)
nounkeyct = 1 ; Set to a 1 to eliminate courtesy tones and associated delays.
totime = 180000 ; transmit time-out time (in ms) (optional, default 3 minutes 180000 ms)
; idrecording = |ie ; id recording or morse string see http://ohnosec.org/drupal/node/87
; idtalkover = |ie ; Talkover ID (optional) default is none see http://ohnosec.org/drupal/node/129
Greetings All
In each Stanza he has the following startup_macro’s which would provide no action unless defined.
Without following Tim’s manual connect request, It is hard to tell what all is not functioning properly or if there are multiple issues.
Perhaps the lack of Macro definitions, USRP ports not being defined on per node in/out basis in each [Nodes] section is the only culprits.
Were it me I would create a new “rpt_conf” and go step by step making each node function properly before adding another or before mixing the different channel drivers and defining their settings.
Larry - N7FM
[523800] ; Change this to your assigned node number
connpgm = /usr/local/bin/kv4s_connect ;CONTENT OF FILE not shown or explained may affect connect issues
discpgm = /usr/local/bin/kv4s_disconnect
[1999]
;rxchannel = dahdi/pseudo ; No radio (hub)
rxchannel = USRP/127.0.0.1:34002:32003
;rxchannel = USRP/127.0.0.1:34001:32001 ; Use the USRP channel driver. Must be enabled in modules.conf
I’m not familiar but does it effect connect issues if not defined in [Nodes] sections ?
[1998]
;connpgm = /usr/local/bin/msg_on_connect
discpgm = /usr/local/bin/msg_on_disconnect
startup_macro = *8348168
[1997]
rxchannel = USRP/127.0.0.1:34003:32002 ; Use the USRP channel driver. Must be enabled in modules.conf
[nodes]
48168 = radio@127.0.0.1:4569/48168,NONE ; This must be changed to your node number
; and iax port number if not the default
523800 = radio@127.0.0.1:4569/523800,NONE
1999 = radio@127.0.0.1:4569/1999,NONE
1998 = radio@127.0.0.1:4569/1998,NONE
1997 = radio@127.0.0.1:4569/1997,NONE
I think it’s working now. I’ll do some more testing to verify.
When I looked at the codes again, I decided to change all my startup nodes to 813XXXXX because that’s what my code is for permanent connections.
813 = ilink,13 ; Permanently connect specified link -- tranceive
his is set for *813 in rpt
Good deal! Enjoy
Tony
K1TNY
WRAW556
Everyone, Thanks for all the help walking through all options.
Had a feeling I was doing something wrong when everyone said how easy it was……
I still wouldn’t mind getting a default rpt.conf to see what I need to clean up in mine.
In this case, your command in startup should be *8131998
Also be certain that no other commands start with 813 or even just 81
Thanks Tony, I did see that, but no where was *813 being used only *83 in his listings. The reason for my comment.
Larry - N7FM
