Passing DTMF node "A" through node "B"
I have read all the similar posts but still don’t have this resolved.
We have node “B” set up with cop’s to send DTMF strings to a remote base through the connected node radio. It works fine using an iPhone with Zopier.
Now we want to be able to either pass through DTMF from node “A” through node “B” to node B’s connected radio or access node “B” cop’s from node “A”. Either way will work for us.
We would very much appreciate some one telling us how this can or can’t be done. Please be very specific in telling us where to place any commands in either node “A” or “B”. I am not a programmer but I can use WinSCP to add lines of code in either node.
Thanks for any posrts.
Wayne
How about this approach?
On node B, where you want the attached radio to send DTMF, write macros that call functions to send out the tones you need. For example you have macro *50 send DTMF 1234. Get that working reliably with out worrying about node A just yet.
[functions]
881=cop,48,1,2,3,4,#            ; Send DTMF 1,2,3,4, and #
See: https://wiki.allstarlink.org/wiki/Transmitting_Tone_Sequences
[macro]
0=*881#     ; execute function 881
Then on node A, write macros that connect to node B and run its macros with the *4 command. For example macro *50 on node A executes macro *50 on node B:
[macro]
0=*3<nodeB>*4<nodeB>*50#
Edit: Actually you could just have node A’s macro do *881 that way you wouldn’t have to have the macros on node B, just the functions.
[macro]
0=*3<nodeB>*4<nodeB>*881#
Thanks for the reply. I will try to work on this this week.
On 11/10/2019 9:34 AM, Tim Sawyer via
AllStarLink Discussion Groups wrote:
wd6awp
wd6awp ASL Admin
              November 10
[functions]
[macro]
*50 on node B:
[macro]
just the functions.
[macro]
Visit
Topic
or reply to this email to respond.
