OT - Looking for a PA Board for a Kenwood TKR-850 UHF Repeater
Hi All:
Been a while!
I am looking for a PA Board for a Kenwood TKR-850 UHF repeater (preferably a PA board from a MK II repeater… but I will take anything that is known to be working!).
Perhaps someone out there has a working board from a repeater with a dead receiver, a spare surplus to requirements, etc.
Appreciate any help in obtaining one.
Ramesh.
VA3UV / WA3UV
Ramesh - at - va3uv dot com
I do not have a specific kenwood pa board you are looking for. I do have a couple Motorola uhf PA from Motorola base and repeater stations that may be applicable if you can simply drive a fairly normal pa with your exciter. If interested let me know and I’ll get you more info including part numbers.
Eric
Sent using SMTP.
On Jun 24, 2020, at 9:09 AM, Ramesh via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
| va3uv
June 24 |
Hi All:
Been a while!
Ramesh.
VA3UV / WA3UV
Hi Eric:
I have a couple of big 19" rack mount Motorola PA’s as well… the PA board in the TKR-850 has seen better days (probably in a 750!!!) - long story… the PA in the 850 is not the proper board for this repeater (I acquired it this way!).
So all I have is a 0dBm signal off the TXRX board to work with. I’d prefer to get the proper PA board as I do like the relatively small / compact form factor of the TKR repeaters.
Thank you for your reply.
Ramesh.
VA3UV / WA3UV
(Attachment pEpkey.asc is missing)
On 2020-06-24 1:25 p.m., Eric via AllStarLink Discussion Groups wrote:
| eric.fort.listmail | eric.fort.listmail
June 24 |
Eric
Sent using SMTP.
··· (click for more details)
In Reply To
| va3uv | va3uv
June 24 |
Hi All: Been a while! I am looking for a PA Board for a Kenwood TKR-850 UHF repeater (preferably a PA board from a MK II repeater… but I will take anything that is known to be working!). Perhaps someone out there has a working board from a repeater with a dead receiver, a spare surplus to require…
