NOOB help with DVSWITCH Brandmister TG please
Good morning all,
If I am posting this in the “WRONG PLACE PLEASE” forgive and point me in the right place to post
New to setting up a DVSWICH server on Hamvoip and need some assistance to figure out what is going and how to correct it.
Did some do diligence and watchec hamcrusader videos and set up DVSWITCH on my hamvoip node.
Set up I started was to provide a DMR Brandmister ASL->DMR bridge, which appears to be successful as I can go into DVSWITCH panel and when I (in supermon) connect 1999 to my node 55373 they link successfully.
Audio successfuly is passed and the world appears to be right, but the TG group displayed in DVSWITCH dashboard is not my Brandmister TG number, but a weird european 986707 TG.
I have looked and read in all my known places and cannot figure out how to change that even when I go to my Brandmister device page and set up a static talkgroup; When I connect the 1999 to 55373, the static TG and the european TG both show up in the DVSWITCH dashboard, but that is not the main issue.....after about 30 or 50 so seconds the audio from the TG I need is muted. The TG still shows on the dashboard and I can see other DMR Id's talking, but no audio is passed to my Brandmister node (in this case 3197538 (plus 11 for the TG)
So the question is where does said 986707 TG come into my life/nightmare and how do I change it?
Many thanks to any and all who can point this noob in the right direction,
73, Adriano KV7D
I would suggest asking this on the DVSwitch community in groups.io. This forum is for AllStarLink.
I would advise not to use 1999 (the example #) as your private node number because, inevitably, you’ll try to connect to some other node, that somewhere on the chain has their OWN 1999 and it’ll refuse the connection (and you won’t know why). Pick a different # from 1000-1998, preferably randomly in the middle somewhere…
I sent you an email to call me. Please call me and I will help you with it.
Brad N8PC
