thought so
that extraneous node definition segment is just how it ships
[nodes]
1999 = radio@127.0.0.1:4569/1999,NONE ; This must be changed to your node number
; and iax port number if not the default
[1999] ; Change this to your assigned node number
didn’t seem to matter if it was there or not, but interesting
It is also important to know that if each node, regardless of server, are connected to a ‘COMMON NODE NUMBER’, the connection will be refused even if they are different private nodes.
It is a loopback protection that did not discount the private node range of less than 2000, but is true for any nodenumber.
was wondering if there was any found reason that little bit of node stanza
was at the top of rpt.conf I confirmed that ASL2.0B6 ships with that in place
First, I do not know for sure that it is a problem having it at the top of the file.
I only asked that you move it and test it ?
Did it resolve anything… results ?
You seem to have an issue of IP assignment.
Are these DHCP? Check your net config files or if you are assigning them by MAC, check your router assignment for error.
Are you also using or have enabled wifi ? Chose one (wired/wifi) and disable the other all together.
You can’t connect to a address that is not there. Suggest wired static addresses…
But I think you have something up in your address assignments.
From a system command line, check network IP’s of each ifconfig
That should be more telling.
And last check the forwarding ‘IP address’ of the ports for typo
To help make sense of all of this unknown,
Could you map this out, and in the process, you might just find the issue.
I am having issues trying to follow along and jumping back and forth on this page is making it worse for I am ADD
Inside your NAT.
Server A
software version
ip address
port
nodes1,nodes2,nodes3
Server B
software ver
ip
port
nodes
Server C
etc
List them all
Sorry to put you through that but it will be the only way I can see it comprehensively. For I am not there. I can not assume anything like I have been. That always gets me in error/trouble.
Please, one post with just that info so I can print it.
OK, got that and while looking at your rpt.conf files you sent a few days ago,
So, 1st thing while I continue to look at all this…
I noticed this and why I said what I did about nodes being described at the beginning of the file,
Because you have 2 [NODES] stanza’s in the file.
The one at the bottom is where it should be. And extra at the top of file.
When I seen the one at the top, I really did not look to the end of the file.
‘Remove’ this at the top of the file rpt.conf, save, reboot - 558936
[nodes]
558936 = radio@127.0.0.1:4576/558936,NONE ; This must be changed to your node number
And on the top of 558993 rpt.conf the same
[nodes]
558933 = radio@127.0.0.1:4567/558933,NONE ; This must be changed to your node number
. So, before I join you in pulling hair out, please test this as corrected.
Mike
most of my testing is shot till spring or later
a fault developed with the 6 meter machine where if it was keyed
the network halted and I do mean HALTED
it started doing that tonight but had been fine for a week
I would up driving out to one of our sites at 22:00 and had to pull power off the Pi
as the transmitter was left sending a test tone with no way to shut it down
glad i didn’t do this in the middle of winter!
I did bring the Pi back with me
