For some reason when I connect to another node the telemetry is not telling me “Node # connected to Node #”. In fact the only telemetry I am getting is the double beep. My Node has been running for several years and I know it was working correctly at some point. Would one of you give me a hint where I should look?
Thanks & 73
Rory, K5CKS
Cop 33 telem on
Cop 34 telem off
rpt config file telemdefault= 0 off 1 on
Setup macro for cop commands if not already in the file.
telemdefault=1 ; 0= t off - 1=t on - 2=on after command and shortly afterwards
cop,34 ; Local Telemetry Output Disable
cop,33 ; Local Telemetry Output Enable
cop,35 ; Local Telemetry Output on demand
cop,37 ; Foreign Link Local Output Path Disable
cop,36 ; Foreign Link Local Output Path Enable
cop,38 ; Foreign Link Local follow local telem
cop,39 ; Foreign Link Local Output Path On-/-Timed
cop,42 ; Echolink announce node # only
cop,43 ; Echolink announce node Callsign only
cop,44 ; Echolink announce node # & Callsign
Thanks for the suggestions. You are right, telemdefault was “Off”. I have corrected this and rebooted but she is still not talking to me. Doug is helping me with this now.
73,
Rory, K5CKS
You might check for the existence of and correct location of the ‘sound files’ and then permissions of those files/directory.
/var/lib/asterisk/sound/
