Node not showing registered
I am having a hard time getting my node registering it keeps saying not registered …I am at a lost i port forward the 4569 in my router UDP and i also did the windows firewall allowance rule my node is 68014
Any help would be greatly appreciated
I can see the 68014 has never successfully registered. I note that you flagged this as a remote base system which is likely incorrect but not likely your issue.
I don't understand why you mention WIndows Firewall?
Can you describe your setup?
Ok The problem was solved
