Hello Ken KE2N, and thanks for your reply.
First your suggestion is the second advice to read more … thanks
Okay, so two node (simple) I disconnected one or disconnet the other and test.
In fact when setting up I was sure to set each port as a different port.
So if you believe that may be the issue where or how can I check ???
