I have a node already but been absent in ham radio for 2 years. I have a RPi3B+ and a BF-888S for my node. Just completed modifying the radio and the soundcard. I have downloaded the asl-2.0.0-beta-4 and flashed it on a 16gb sd card. I was able to get into the configuration for the first time and followed the Beginners Guide and Allmon2 Setup. I faced a problem where it says $ chmod 777 astdb.php. It says no such file or directory. Also, when I login to the Allmon2 via the web browser, I get a login fail message. I did set my admin password via the htpasswd and also edited the manager.conf.
Is there a step by step instructions or a link to a video on how to set this up from start to finish and do some audio test?
Thank you for the reply. How can I send this files to you? I tried to attached it here but I got an error saying the files are not supported as attachment. I tried sending to your email add but it’s blocked by gmail. Sorry.
Thanks Rob. I followed your instructions and changed what needs to be changed and reboot the Pi. But I still have the same “Sorry, login failed” message.
