I will preface with the fact that most of my stuff is online and public as are the other stations I refer to here. That said… I am trying to experiment with exploring private nodes and static connections. I setup a private node [1999] with IAX only access for my brother to call me on, it works great… Next I want to have my dad’s private number [1957] connected all the time static to my [1999] node. I think I understand about mapping the ip addresses in both rpt.conf files.
The first (and hopefully only) issue I am having is the rxchannel configuration. You see my first private node [1999] is using rxchannel = USRP/127.0.0.1:34001:32001 and my public node [42177] is using rxchannel = dahdi/pseudo. This particular server is in the cloud, so no usb audio is used.
So what should I assign to node [1957] to avoid conflict or errors?
I am very happy with the results of USRP and Dhadi both, but don’t know if I can simply add a digit at the end of the channel name like a suffix and that be sufficient, such as dhadi/pseudo2. Would there be conflicts? If I were to do this where all would I need to add it besides rpt.conf? What happens if I receive on both nodes at the same time? I guess the conflict I am worried about is a port conflict. With USRP I could define a different range it seems, but in modules.conf there is only one module for usrp, so I would need to add another correct?
