Minimal audio from node to or from repeater controller
Hello all. Having an issue with audio passing to and from our node that is in our repeater. With the RX and TX settings in simpleusb set to 999 barely any audio is passed through to the repeaters or vice versa. The repeaters go to an Arcom Rc210 controller then connect to a RIM lite RC210 interface to a USB cable to the Linux PC. At a loss as we have verified all settings in ASL3 and in the controller software. If anyone has any input or help please let me know. As a point for reference the two repeaters that are also linked on this controller have no audio issues, and when the node transmits it does key the repeaters up but passes dead air. Thanks in advance.
ASL3 debian appliance install Trixie flavor
Dell Optiplex 7010 running the node
If you need more I can provide it.
Are you able to measure what the Vpp is on the audio into the RIMLite? You want it ideally to be nominally between 0.5v and 2v Vpp. Also, have you counter-intuitively tried making the receive level very low? If you have really hot audio it could be clipping out.
Receive audio on ASL3 or at the controller? We will have to check the voltage next time we can get to the site, as we have it co located with county gear and have to have a county approved escort to gain access to the building. But if I don't have a list of things to check when we go I may bang my head into a live transmitter lol.
I’d just start with the basics. Use the tune menu, does flash result in proper keying and a loud test tone? Does the rx meter (iirc option 2) deflect when its receving audio? The RC-210 has audio adjustments (both ways) for each port, without knowing how low is low, i guess someone could have got in there and turned them both all the way down. The other suggestions on measuring audio as well should help find the issue quickly.
Flash feature keys repeaters but no audio tone it emitted, option the cursor never moves when either repeater is transmitted into. Will reverify the rc-210 trim pots next time we are on site but the guy that was inside the controller claims he turned them up all the way, but maybe that was too far. Please keep the suggestions and questions coming.
Rx and tx audio lines inverted???
Possibly but have made a new cable to elimate that issue for our next site visit. Someone did say they heard faint audio if they turned their ASL3 connected radio all the way up, put the radio by their ear an plugged their other ear. So it's possible the audio pots are turned down versus up but I want to be armed with as much info as I can be as our time is limited when we do get access to the site. Thanks everyone.
Well your OP reported "barely any audio" is passing but that test showed NO audio. I'd just double check your wiring to make sure everything is going to the right pins. Those two tests (flash and RX deflection) need to work before any audio fine tuning takes place.
The RC-210 has a bunch of configuration options. I'd make sure audio is passing from the port the rim-lite is plugged into actually goes to the repeater (or maybe transmitter is a more accurate way to say that). A scope and a basic AF sig generator would make quick work out of this. Even a old telephone butt-phone or a small speaker (wont be loud but you can hear it) will tell you if there is audio there or not.
On the subject of test equipment, "getting the audio in and out of the repeater" is only the start. You should use some real test gear to make sure the deviation is set correctly (and matches the other audio sources, like repeater audio). "turning things all the way up" is going to be a mile from correct.
And on the subject of repeaters and controllers, be sure to watch the audio filtering (de and pre-emphasis), often repeaters and controllers are set for flat audio and allstar needs to be configured correctly (the default isn't set for this type of audio). There are existing materials to help you through all that. And be careful when you ask people what "flat" audio is. You'll get a number of answers. :slight_smile:
Repeater audio between repeaters is already set and is fine. The issue is the computer running asl3 to run lite to controller interface I believe. Deviation on the repeaters was set with a service monitor. Asl3 was configured for no ctcss and flat audio, and the controller was set accordingly as well just to clarify that portion. I'm leaning towards audio lines crossed or the audio for the controller port we have asl3 connected to being turned down versus up.
I don't know much about the RC-210 (actually nothing other than they exist). However just because infra-repeater audio is tuned doesn't mean that the audio being pushed into a different audio port is set right. For example on an SCom 7330, there's a TX pot for every audio path. Having our repeater's audio tuned does nothing for the ASL audio path. Similarly, tuning the repeater is often an exercise of setting the RX and then matching up the TX. Your RX could be really low and your TX tuning is compensating, but the RX is too low for ASL. Additionally, again, you could be clipping out if the RX is burning hot and the TX tuning is compensating. You need to ensure that actual audio is coming out of your RC-210 and entering the adapter on the ASL. The best way (and most annoying to do in the field) is an oscilloscope looking at a 1 kHz test tone. Alternatively, use the simpleusb-tune-menu with the rx tuning screen and move the audio adjusters on the RC-210 up and down.
Yeah we are thinking that would be easiest. We can asked one of the repeaters committee guys if he has a portable oscilloscope
Having hauled an o-scope out to the field a number of times to tune things, you have my sympathies...
Thanks. Lol. I know how heavy they are, I've moved a few in my life.
