I just used that one as an example . . .
but ones like *721 to id do not work either.
On my Pi4 running Debian GNU/Linux 12 (bookworm) all the command execute fine.
Even the ones that call the shell scripts.
It is probably something obvious but i just cant see it.
functions-main
;;;;;;;;;;;;;;;;;;; functions stanza ;;;;;;;;;;;;;;;;;;;
; Prefix Functions
; *1 Disconnect Link
; *2 Monitor Link
; *3 Connect Link
; *4 Command Mode
; *5 Macros
; *6 User Functions
; *7 Connection Status/Functions
;; *8 <-- User Functions
;; *9 <-- User Functions
;; *0 <-- User Functions
; *A User Functions
; *B User Functions
; *C User Functions
; *D User Functions
;;;;;; Mandatory Command Codes ;;;;;
1 = ilink,1 ; Disconnect specified link
2 = ilink,2 ; Connect specified link -- monitor only
3 = ilink,3 ; Connect specified link -- transceive
4 = ilink,4 ; Enter command mode on specified link
70 = ilink,5 ; System status
99 = cop,6 ; PTT (phone mode only)
;;;;; Macro Commands ;;;;;
;; 5 = macro :: <<--- disabled for DTMF commands via bash script
;;;;; Autopatch Commands ;;;;;
; Note, This may be a good place for other 2 digit frequently used commands
;61 = autopatchup,noct = 1,farenddisconnect = 1,dialtime = 20000 ; Autopatch up
;62 = autopatchdn ; Autopatch down
; autopatchup can optionally take comma delimited setting=value pairs:
; context = string ; Override default context with "string"
; dialtime = ms ; Specify the max number of milliseconds between phone number digits (1000 milliseconds = 1 second)
; farenddisconnect = 1 ; Automatically disconnect when called party hangs up
; noct = 1 ; Don't send repeater courtesy tone during autopatch calls
; quiet = 1 ; Don't send dial tone, or connect messages. Do not send patch down message when called party hangs up
; Example: 123=autopatchup,dialtime=20000,noct=1,farenddisconnect=1
;;;;; Status Commands ;;;;;
; 1 - Force ID (global)
; 2 - Give Time of Day (global)
; 3 - Give software Version (global)
; 4 - Give GPS location info
; 5 - Last (DTMF) user
; 11 - Force ID (local only)
; 12 - Give Time of Day (local only)
721 = status,1 ; Force ID (global)
722 = status,2 ; Give Time of Day (global)
723 = status,3 ; Give software Version (global)
724 = status,4 ; Give GPS location info
725 = status,5 ; Last (DTMF) user
711 = status,11 ; Force ID (local only)
712 = status,12 ; Give Time of Day (local only)
;;;;; Link Commands ;;;;;
; 1 - Disconnect specified link
;;; . . ** ALL COMMENTED OUT **
; 18 - Permanently connect specified link -- local monitor only
;;;;; ilink commands ;;;;;
; commands 1 through 5 are defined in the Mandatory Command section
959 = ilink,6 ; Disconnect all links
; 806 = ilink,6 ; Disconnect all links
; 807 = ilink,7 ; Last Node to Key Up
;;; . . ** ALL COMMENTED OUT ** ; Reconnect links disconnected with "disconnect all links"
; 817 = ilink,17 ; MDC test (for diag purposes)
; 818 = ilink,18 ; Permanently connect specified link -- local monitor only
;;;;; Control operator (cop) functions. ;;;;;
;Change these to something other than these codes listed below!
;901 = cop,1 ; System warm boot
;902 = cop,2 ; System enable
; 958 = cop,58 ; TX CTCSS On Input only Enable
; 959 = cop,59 ; TX CTCSS On Input only Disable
; 960 = cop,60 ; Send MDC-1200 Burst (cop,60,type,UnitID[,DestID,SubCode])
; Type is 'I' for PttID, 'E' for Emergency, and 'C' for Call
; (SelCall or Alert), or 'SX' for STS (ststus), where X is 0-F.
; DestID and subcode are only specified for the 'C' type message.
; UnitID is the local systems UnitID. DestID is the MDC1200 ID of
; the radio being called, and the subcodes are as follows:
; Subcode '8205' is Voice Selective Call for Spectra ('Call')
; Subcode '8015' is Voice Selective Call for Maxtrac ('SC') or
; Astro-Saber('Call')
; Subcode '810D' is Call Alert (like Maxtrac 'CA')
; 961 = cop,61 ; Send Message to USB to control GPIO pins (cop,61,GPIO1=0[,GPIO4=1].....)
; 962 = cop,62 ; Send Message to USB to control GPIO pins, quietly (cop,62,GPIO1=0[,GPIO4=1].....)
; 963 = cop,63 ; Send pre-configured APRStt notification (cop,63,CALL[,OVERLAYCHR])
; 964 = cop,64 ; Send pre-configured APRStt notification, quietly (cop,64,CALL[,OVERLAYCHR])
; 965 = cop,65 ; Send POCSAG page (equipped channel types only)
;===== [CUSTOM TONE functions] ==========
981=cop,48,!700/100,!900/60 ; DT 1331 Connect
982=cop,48,!500/100,!1400/60 ; DT DMR Connect
983=cop,48,!900/100,!1900/60 ; DT ASL Connect
984=cop,48,!800/100,!1200/60 ; DT ASL Monitor
985=cop,48,!499/100,!339/60 ; DT ALL Disconnect
989=cop,48,!800/60,!1000/60 ; two tone Command Accepted
;============================= SkywarnPlus =============================
; SkyControl DTMF Commands
831 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py enable toggle ; Toggles SkywarnPlus
832 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py sayalert toggle ; Toggles SayAlert
833 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py sayallclear toggle ; Toggles SayAllClear
834 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py tailmessage toggle ; Toggles TailMessage
835 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py courtesytone toggle ; Toggles CourtesyTone
836 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py alertscript toggle ; Toggles AlertScript
837 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py idchange toggle ; Toggles IDChange
838 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py changect normal ; Forces CT to "normal" mode
839 = cmd,/usr/local/bin/SkywarnPlus/SkyControl.py changeid normal ; Forces ID to "normal" mode
; SkyDescribe DTMF Commands
841 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 1 ; SkyDescribe the 1st alert
842 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 2 ; SkyDescribe the 2nd alert
843 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 3 ; SkyDescribe the 3rd alert
844 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 4 ; SkyDescribe the 4th alert
845 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 5 ; SkyDescribe the 5th alert
846 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 6 ; SkyDescribe the 6th alert
847 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 7 ; SkyDescribe the 7th alert
848 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 8 ; SkyDescribe the 8th alert
849 = cmd,/usr/local/bin/SkywarnPlus/SkyDescribe.py 9 ; SkyDescribe the 9th alert
;============== Tx31 [BCAST COMMANDS] ==================================
040 = cmd,/etc/asterisk/local/040-playARN-now.sh ; PLAY ARNewsLine
;============== Tx31 [WX COMMANDS] =========================
041 = cmd,/etc/asterisk/local/041-READ-WX-TTS.sh ; READ AFDBOU
042 = cmd,/etc/asterisk/local/042-READ-WX-TTS.sh ; READ HWOBOU
;; 048 = cmd,/etc/asterisk/local/948-PLAY-WX-TTS.sh ; READ Space WX
049 = cmd,/etc/asterisk/local/049-PLAY-WX-TTS.sh ; PLAY Tropical WO
;============== Tx31 [set Node+Channel TX/RX] =========================
;; 50 = cmd,/etc/asterisk/local/ ; ** NODE PARROT
051 = cmd,/etc/asterisk/local/Node-tune.sh TX 410460 ; PRA (RX)
651 = cmd,/etc/asterisk/local/Node-tune.sh RX 410460 ; PRA (TX/RX)
052 = cmd,/etc/asterisk/local/Node-tune.sh TX 46079 ; SkyHub Link (RX)
652 = cmd,/etc/asterisk/local/Node-tune.sh RX 46079 ; SkyHub Link (TX/RX)
053 = cmd,/etc/asterisk/local/Node-tune.sh TX 485322 ; SkyHub SVRWX (RX)
653 = cmd,/etc/asterisk/local/Node-tune.sh RX 485322 ; SkyHub SVRWX (TX/RX)
;; 054 =
;; 654 =
055 = cmd,/etc/asterisk/local/Node-tune.sh TX 576337 ;* WX5OKM OK (RX)
655 = cmd,/etc/asterisk/local/Node-tune.sh RX 576337 ;* WX5OKM OK (TX/RX)
;============== Tx31 [set TGIF TX/RX] =========================
070 = cmd,/etc/asterisk/local/TG-tune.sh TGIF TX 91910 ; RV America TG (TX/RX)
071 = cmd,/etc/asterisk/local/TG-tune.sh TGIF TX 2021 ; FreeSpeech TG (TX/RX)
072 = cmd,/etc/asterisk/local/TG-tune.sh TGIF TX 31665 ; Mothership TG (TX/RX)
073 = cmd,/etc/asterisk/local/TG-tune.sh TGIF TX 117 ; HF talk TG (TX/RX)
074 = cmd,/etc/asterisk/local/TG-tune.sh TGIF TX 59650 ; TX-DFWS TG (TX/RX)
075 = cmd,/etc/asterisk/local/TG-tune.sh TGIF TX 756 ;* KD5FMU TG (TX/RX)
076 = cmd,/etc/asterisk/local/TG-tune.sh TGIF TX 7399 ; ARMS TG (TX/RX)
079 = cmd,/etc/asterisk/local/TG-tune.sh TGIF RX 31670 ;World Wide Talk (TX/RX)
;============== Tx31 [set BM TX/RX] =========================
;; 080 = cmd,/etc/asterisk/local/TG-tune.sh TGIF TX 9990 ; ** BM PARROT
081 = cmd,/etc/asterisk/local/TG-tune.sh BM TX 91 ; World Wide (TX/RX)
082 = cmd,/etc/asterisk/local/TG-tune.sh BM TX 93 ; North America (TX/RX)
083 = cmd,/etc/asterisk/local/TG-tune.sh BM TX 31088 ; Colorado HD (TX/RX)
;============== Tx31 [Node BRIDGE COMMANDS] =========================
952 = cmd,/etc/asterisk/local/850-TGIF-bridge.sh ; 1331 TGIF bridge
953 = cmd,/etc/asterisk/local/950-BM-bridge.sh ; 1331 BM bridge
;============== Tx31 [CONTROL COMMANDS] =========================
066 = cmd,/etc/asterisk/local/066-DROP-ALL-CMD.sh ; DROP-ALL LINKS
9751 = cmd,/etc/asterisk/local/server-reboot.sh ; node reboot
9750 = cmd,/etc/asterisk/local/server-shutdown.sh ; node shutdown
9755 = cmd,/etc/asterisk/local/9755-XC-Tx21.sh ; Cross Connect Tx21
; [functions-remote]
;;;;; Functions for remote bases ;;;;;
; 0 = remote,1 ; Retrieve Memory
; 1 = remote,2 ; Set freq.
; 2 = remote,3 ; Set TX PL tone
; 726 = remote,117 ; Scan + quick
; 729 = remote,118 ; Scan + fast
; 79 = remote,119 ; Tune
; 91 = remote,99,CALLSIGN,LICENSETAG ; Remote base login.
; Define a different DTMF sequence for each user which is
; authorized to use the remote base to control access to it.
; For example 9139583=remote,99,WB6NIL,G would grant access to
; the remote base and announce WB6NIL as being logged in.
; Another entry, 9148351=remote,99,WA6ZFT,E would grant access to
; the remote base and announce WA6ZFT as being logged in.
; When the remote base is disconnected from the originating node, the
; user will be logged out. The LICENSETAG argument is used to enforce
; TX frequency limits. See [txlimits] below.
; 85 = cop,6 ; Remote base telephone key
functions
