here is my how-to write up. hope it helps someone someday!
Yup. And with persistent connections, only the hub needs to be told to do so
Nice work! If you’re interested in automating Newline broadcasts on all your nodes, here’s how
Just a note to others stumbling on this, the earlier issue of kb5won’s issue with dahdi was from doing a update upgrade before putting a freeze on the kernel headers that is also listed in the text file where the image was downloaded.
The version of dahdi was not compatible with later kernel’s.
The later beta resolves this issue.
