When a new node is requested the default is for the Web Transceiver to be enabled. To disable it and remove the “wt” the AllStar Node List, go into your Node Settings and set Allow Web Transceiver access? to No. That will prevent all users, including yourself from connecting to your node with the Web Transceiver.
