Is there an example set for the .conf files ( voter , rpt , … ) using rtcm’s ?
I can find individual ones but not a " set " or files that are from one server implementation .
I realize this is a big question , but just would like to look at a working set.
Initial setup using asl-menu didnt save node # … ( even after hitting save )so was editing manually with als-menu and nano .
using allstar beta installed in debian 10 , also have downloaded and installed on a different computer 1.01 .
have just done the fresh install of 1.10 .
We have 4 rtcm’s one at master site with a repeater , and 3 satellite receive only sites .
we are attempting to replace a failed voter system ,
on the beta / deb 10 system I was expecting the .conf to get populated with a skeleton that gets completed , have not tried deb 9 / 1.01 computer doing that now.
Just if I can get a set of .conf that are a working example that’s close it would be helpful .
For a voter system you only need one node for the entire system. Therefore all the config files except voter.conf are identical, other than one minor change to rpt.conf, to a one node setup. Once you have a regular node running you are ready to work on voter.conf and the RTCM settings.
The change to rpt.conf is the channel driver for RTCMs. That is rxchannel = Voter/1234 where 1234 is your node number. This points into voter.conf which is were all your chanvoter settings are stored.
