Messed up a node install and starting over from asl-menu functions does not help. Node is 50 miles and 400 feet up so correcting from a fresh SD card build is not easy or timely.
simpleusb-tune menu returns “Error parsing device parameters”
Trying to translate/verify “devstr=” nomenclature in simpleusb_tune_<node#>.conf vs. data from lsub output…
Bus 001 Device 004: ID 0d8c:013a C-Media Electronics, Inc.
How should that be properly expressed and recognized in the .conf file?
devstr=1-4 ?
Any other places/files/strings that need to match up so asterisk recognizes the interface?
Yes - ASL 2.0, Beta 6. 3rd node running it, this first live node on-site for us using it.
As to the issues stated - it appears coffee and less-fat-fingering corrected/aligned all of the node/interface declarations and it’s now working fine. (Backups saved!)
