I am bench testing a new repeater system with a Yaesu DR-2X, ARCOM RC210, and the RIM_RC210. The AllStar Node is working great, but there is a problem with EchoLink users connecting inbound. If I connect to the user first and then disconnect, they can then connect. I have the Port Forwarding set up correctly. We had EL previously using a ULI and had no problems. I checked and rechecked the rpt.conf and echolink.conf and can find nothing apparently wrong there. Another problem is when I connect to the EchoLink Test Server, the return audio is awful and echoes, not a pun intended.
It turned out to be a port forwarding error. Couldn’t see the forest for the trees. Thank for all who gave advice and/or suggestions. It is functioning nicely now.
