When did you do that install?
I installed the ASL3 RPi image (allstar3-arm64-3.0.10.img) on the same RPi I tried apt install asl3.
I used the same node number (2149)
raspberrypiCLI> rpt show version
app_rpt version: 3.0.1
raspberrypiCLI> core show version
Asterisk 20.8.1+asl3-3.0.2-1.deb12 built by builder @ allstarlink.org on a aarch64 running Linux on 2024-07-07 22:46:48 UTC
After booting, I used asl-menu to configure node.
*342565 works fine.
All of my testing was done over the last couple of days. I have always done “apt install asl3”
I have always only used asl-menu to configure node.
Installed tmate on my Mac but no idea what to do with it. Give me a clew.
No need. If I installed it on a host then you just ssh to a reverse ssh proxy. Use the VM IP I sent.
Wise-3040*CLI> rpt fun 2149 *342564
[2024-07-25 18:23:36.459] DEBUG[3122]: app_rpt/rpt_config.c:395 node_lookup_bydns: Resolving DNS SRV records for: _iax._udp.4256.nodes.allstarlink.org
Should be resolving for _iax._udp.42565.nodes.allstarlink.org Something is truncating the lookup.
@N4IRS Thanks for keeping folks updated on this.
Further details: we found that the problem only happens if all of the following are true
- Lookup is set to dns:
node_lookup_method = dns. - There are only 4 digit nodes on the server.
- Connecting with DTMF. ie will occur
rpt fun ...but will not occur withrpt cmd ...
We have a fix in the works and expect get it out this week.
