the crash is caused when accessing the the remote base node
using the asterisk manager interface via allmon2
by the way.
ken n1dot
On 12/12/2015 2:02 PM, Steve Zingman
wrote:
Ken,
I now better understand. I'll work on something that will solve
the restart from crash.
I will also look into what is causing the crash since I also have
a 706 as a remote base.
Thanks, Steve
This email has been sent from a virus-free computer protected by Avast.
www.avast.com
On 12/12/2015 01:50 PM, Kenneth
Grimard wrote:
hi steve
the main issue steve is not the fact that service asterisk restart does not work. but the main issue is that if asterisk crashes for any reason it will not restart itself. because of this i also can not use cop,1 cop command which is asterisk restart. cop,1 will cause asterisk to exit for restart but asterisk will not restart via a watchdog script. safe_asterisk used to do this very nicely but it has been
eliminated.
and you only use the asterisk service script under systemd. yes the version of the asterisk service script i have here from
the
dial build from about 4 to 5 weeks ago the service asterisk restart does not work. it force's me to use service asterisk stop to remove the asterisk.ctl file from the /var/run and the the service asterisk start will then work allowing asterisk to be restarted proprely. I also have a node setup for remote base mode using an ic-706mkiig and sometimes that will cause a crash with it. when asterisk is accessed via an allmon2 dashboard. I have had to take the remote base node off of the allmon2 page to stop this crashing. it will do it every time too. that is something with the old remote base code with in app_rpt.c too which has never been fixed. this is why the asterisk auto restart on crash would be very
nice
where can i find a new or updated asterisk service script. can i get it from the rpi2 dial image and put in the dial x86 build with out having to re-install dial x86 image? otherwise for the most part asterisk under dial has been fairly stable. but i can make it crash under certain conditions which i try to avoid. like using allmon2 to access the remote base node via the asterisk manager interface. ken n1dot
On 12/12/2015 1:01 PM, Steve
Zingman wrote:
Ken,
As I posted below I could not recreate your issue. is there
anything I’m missing?
73, Steve root@repeater:~# asterisk -r Asterisk 1519, Copyright (C) 1999 - 2008 Digium, Inc. and
others.
Created by Mark Spencer Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show
warranty’ for details.
This is free software, with components licensed under the GNU
General Public
License version 2 and other licenses; you are welcome to
redistribute it under
certain conditions. Type ‘core show license’ for details.Connected to Asterisk 1519 currently running on repeater (pid
= 4407)
repeaterCLI> rpt cmd 2150 cop 1 2150
repeaterCLI> Killed
root@repeater:~# service asterisk restart
others.
Created by Mark Spencer Asterisk comes with ABSOLUTELY NO WARRANTY; type ‘core show
General Public
= 4462)
repeater*CLI>
markster@digium.com
On 12/12/2015 11:50 AM, Kenneth
Grimard wrote:
I download the dial release and installed it just after is
first came out
that was about 4 weeks ago. now if asterisk crash for any reason or if you use the cop,1
cop command
it will not restart is self at all. you have to go into an
ssh shell and issue a
service asterisk stop then a service asterisk start. the service asterisk restart does not work for me on the x86
release.
there seems to be no way for asterisk to restart itself
after a crash
or after using the cop,1 cop command. has there been any updates to the asterisk service command for systemd to fix this? ken n1dot
On 12/12/2015 7:16 AM, Steve
Zingman wrote:
Neil,
I misread your message last night. I just tested service asterisk restart on DIAL x86
restarts a dead asterisk. See below.
` ps ax | grep asterisk
�1081 ?������� Ssl��� 0:01 /usr/sbin/asterisk
�1117 pts/0��� S+���� 0:00 grep asterisk
kill -9 1081
�1125 pts/0��� S+���� 0:00 grep asterisk
asterisk -r
and others.
show warranty’ for details.
the GNU General Public
details.Unable to connect to remote asterisk (does
/var/run/asterisk.ctl exist?)
�1143 ?������� Ssl��� 0:00 /usr/sbin/asterisk
�1171 pts/0��� S+���� 0:00 grep asterisk
asterisk -r
and others.
(pid = 1143)
repeater*CLI> `73, Steve N4IRS
root@repeater:/etc/init.d#
On 12/12/2015 12:44 AM, Neil
k8it wrote:
Steve
I have been evaluating Dial on
a Linux PC
Observations
1. When asterisk crashes,
there is no restart or watchdog
2.this makes debugging very
difficult
3.asterisk service mode
restart does not seem to work
4. in this mode remote SSH to
restart is not possible
Do you have any fixes planned?
73 Neil Sablatzky� K8IT Allstar Node 41838 KITLINK Allstar Node 42087 KITLINK HUB IRLP Node exp0068 Echolink K8IT-L WIRES-X K8IT 11479 Room 21479
_______________________________________________ .
1st Law of Logic
This
protected by Avast.
[www.avast.com](https://www.avast.com/?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient)
1st Law of Logic
1st Law of Logic
