I see many different ways of doing the same thing in crontab and would like to learn the difference. Granted my Linux usage is limited.
58 18 * * * /usr/bin/asterisk -rx “rpt cmd node1 ilink 3 node 2”
58 18 * * * /usr/bin/asterisk -rx “rpt fun node1 *3node2”
So what is the difference between the cmd and fun and where do I find this. In general Linux documentation or AllStar or Hamvoip specific Documentation?
Thanks
In terms of cron there is no difference. Cron is merely starting asterisk with different app_rpt functions. As to why there is a cmd and fun (and fun1) to do the same things I can’t say.
One way to learn the commands is the use of tab and return. Short example:
*CLI> rpt <tab>
cmd debug dump fun fun1 localnodes localplay lstats nodes page playback reload
restart sendall sendtext setvar showvars stats xnode
*CLI> rpt fun<tab>
fun fun1
*CLI> rpt xnode <cr>
Usage: rpt xnode <nodename>
Dumps extended node info to the console
Usage: rpt fun <nodename> <command>
Send a DTMF function to a node
Usage: rpt cmd <nodename> <cmd-name> <cmd-index> <cmd-args>
Send a command to a node.
i.e. rpt cmd 2000 ilink 3 2001
Adding to that, “rpt fun” is identical to using a DTMF function over the air. This requires the exact same configuration of defining the DTMF string and assigning it the proper command in rpt.conf. In contrast, “rpt cmd” directly runs commands and does not require that configuration beforehand.
As I mentioned in the post Tim referenced, using “rpt cmd” can provide security in some cases. If not needed, not defining a DTMF string for a command prevents anyone with over the air access and DTMF capability from running that command. In this case, either using cron or manually via the command line through ssh, etc. , the ability to run that command is only available to properly authenticated users when using “rpt cmd”.
Well thanks for all the answers it make a little more sense now…
Appreciate the help. One of my mentors does it one way and the other does it the other…
