I recently made the mistake of changing one of my many nodes UDP port in a node to the same UDP port on another node on the same LAN. After correcting the mistake. I’ve noticed that when using supermom to make connections to nodes in my favorites tab that I now have a notification that “connection failed” on all but the WIN 2560 node. This happens on both nodes affected. All other nodes on the LAN are working fine in this regard.
I have tried reimaging the SD card, using a different node number, different static IP address, different AllStar server, all to no resolution.
What I have done is move my node to a new new node number and server on the system after reimaging the SD card. Node 513781 and to a different UDP port 4570. Looking through the rpt. Conf files looks OK. I still can’t connect to any nodes on the system via DTMF or Supermom but node 513780 on 4569 is fully operational. These two nodes are the only two on this series of NNX nodes. Totally lost at what to do.
I’m considering giving back my node assignments and starting from scratch.
