The repeater controllers we use on our system strips any DTMF tones received after a * is used. Is there any way to change the * prefix to something else like 11
Ted
W6SAT
Ted
W6SAT
Yes there is. It’s called inxlat. It’s documented on our Wiki.
Thanks Tim. I tried the following and it didn’t work.
inxlat=#56,#57,0123456789ABCD
DTMF sent to the repeater to control internal node 1100 from node 1110: #5641100 then #56149XXX
Seems that should have disconnected internal node 1100 from our hub node 49XXX
I had asterisks CLI running in the background to see if the DTMF tones were received and they were.
Please try removing the commas.
I’ll try that.
Is the wiki wrong in that respect then?
It might be a bad example in the WiKi. I’ve always heard that is not possible to change the # function in AllStar yet the WiKi example shows exactly that.
I have inxlat= *,#,0123456789ABCD,Y
in one of my nodes and I change the *
to *<something>
in another one. Both work as advertised.
I will say that using AllStar behind a regular repeater controller is not optimal for a number of reasons. The one exception is using RTCM’s in mix-minus mode. That works quite well in a network of repeater controllers. Typical use case for that is replacing 420 links.
What does the “Y” do at the end of the inxlat line?
It makes dial tone after the prefix (the * normally) is entered.
I see that now on the Wiki.
Ted
