Any one used that channel driver?
I know that is not a normal channel driver.
I have a project of feeding audio to and from a local node.
So if anyone have experience with this let me know.
Pierre
VE2PF
Pierre
VE2PF
No one ever used Alsa radio? ok… looks like I will have to play a bit with this.
Pierre
VE2PF
Hi Pierre,
On 17 Jan 2019, at 11:48 am, Pierre Martel <petem001@gmail.com> wrote:
No one ever used Alsa radio? ok.. looks like I will have to play a bit with this.
I’m currently looking at chan_alsaradio to get an OrangePC Zero working. I’ve just finished building a QEMU based Jessie build environment (very slow, but seems usable) and am slowly working through dependancies to get it compiled.
Carl.
(vk1kcm)
ok! I will be working on RPI.
Starting the test this week end
Le ven. 18 janv. 2019 à 04:40, Carl Makin carl@stagecraft.cx a écrit :
Hi Pierre,
Carl.
(vk1kcm)
Sorry to dig up an old thread, but I’m also interested in this channel driver. However, instead of using ttyS0 for signalling I’d like to use the CM108B’s GPIO1 and GPIO4 in the same way that the simpleusb channel driver does.
How does one build a channel driver from source and load it in Asterisk without having to recompile Asterisk from source? Is this even possible?
73s,
Jonathan
