[App_rpt] Remote Base?
Good news, it works! Thanks for the help and it appears there are a lot of
hidden 'features' I need to learn about...
Gary
-----Original Message-----
[mailto:app_rpt-bounces@lists.illiana.net] On Behalf Of Jim Duuuude
Sent: Saturday, October 28, 2006 1:47 PM
To: app_rpt@lists.illiana.net
Subject: Re: [App_rpt] Passing DTMF?
On my test node (102), I set the following:
duplex = 0 ; No duplex, no
response (mostly)
propagate_dtmf = yes ; Propigate
non-function DTMF digits
linktolink = yes
On my normal node (2001), I hit *3102 to bring up a full
duplex link to
node 102. I then go into command mode for node 102, by
entering *40 (since 102 was the last addressed node). Then,
whatever touchtones I hit, like 123 comes out the transmitter
of node 102 just like it should.
Gary, See below--
Thanks for the info. Confirm you must go into command mode to generate the
DTMF?
Yep.
I was not using command mode (I don't really understand what it command
mode is) so that could be the problem.
The purpose of Command Mode makes is to make your local node command decoder
ignore any DTMF, and instead forward it over the link to the far end where it
gets decoded. When you are in commend mode, you should hear an extra beep in
the courtesy tone sequence on the node you are accessing. You must remember
to exit Command Mode when you are finished commanding the local node. If you
do not, no audio will passed in command mode.
My config is the same as yours so hopefully it is the lack of 'command
mode' that was the problem. I'll try it and see what happens.
Tell me more about using the '0' feature instead of a node number.
0 is shorthand for the last valid node number entered.
If you connect to node 1234 using *31234, you can go in to command mode on
node 1234 by dialing *40, or disconnect from node 1234 by dialing *10.
On Saturday 28 October 2006 18:57, Gary Young wrote:
Gary
> From: app_rpt-bounces@lists.illiana.net
> response (mostly)
> linktolink = yes
> duplex link to
App_rpt mailing list
App_rpt@lists.illiana.net
Hello friends,
For those who want to build a very simple interface for a simplex radio
behind a single FXS Asterisk interface as a Digium TDM400P or TDM2400P :
http://www.hamwlan.net/images/FXS-SIMPLEX-RADIO-V2.jpg
Have fun !
73,
F6HQZ,
Francois BERGERET,
France.
Very nice, Thanks!
Gary
f6hqz-m@hamwlan.net
Sent: Sunday, October 29, 2006 1:55 AM
To: 'Asterisk Repeater Controler'
Subject: [App_rpt] Simplex radio interface
Hello friends,
simplex radio
TDM2400P :
Have fun !
73,
F6HQZ,
Francois BERGERET,
France.
Is it true there are only 10 Macros available? 1-9 and 0 the system Macro?
Is it possible to add a pause in a macro?
With a Macro I would like to:
-Connect to a node in command mode.
-Send out DTMF
-Pause
-Send out more DTMF
-Pause
Gary K6HN
if you only use single digit strings. Use longer strings and you can have more.
Reply-To: pcfrover@tcomeng.com,Asterisk Repeater Controler <app_rpt@lists.illiana.net>
To: "'Asterisk Repeater Controler'" <app_rpt@lists.illiana.net>
Subject: [App_rpt] Macro's and DTMF
Date: Sat, 4 Nov 2006 09:07:34 -0800
MIME-Version: 1.0
Received: from lists.illiana.net ([207.227.243.140]) by bay0-mc4-f18.bay0.hotmail.com with Microsoft SMTPSVC(6.0.3790.2444); Sat, 4 Nov 2006 09:05:39 -0800
Received: (qmail 28402 invoked from network); 4 Nov 2006 17:05:37 -0000
Received: from localhost (HELO ?127.0.0.1?) (127.0.0.1) by 0 with SMTP; 4 Nov 2006 17:05:37 -0000
Received: (qmail 28361 invoked from network); 4 Nov 2006 17:05:33 -0000
Received: from alnrmhc11.comcast.net (206.18.177.51)by 0 with SMTP; 4 Nov 2006 17:05:33 -0000
Received: from den (c-69-181-173-31.hsd1.ca.comcast.net[69.181.173.31])by comcast.net (alnrmhc11) with SMTPid <20061104170532b1100fjv1ee>; Sat, 4 Nov 2006 17:05:32 +0000
X-Message-Info: txF49lGdW40TP9dR9j0egTaMN0lvXu1SBgBjYCFagKM=
Return-Path: <pcfrover@tcomeng.com>
Delivered-To: mailman-app_rpt@lists.illiana.net
X-Mailer: Microsoft Office Outlook 11
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2962
thread-index: Acb77xJVOBM4uGmNQoKoQM1TBJKnrgERDBQQ
X-BeenThere: app_rpt@lists.illiana.net
X-Mailman-Version: 2.1.6
Precedence: list
List-Id: Asterisk Repeater Controler <app_rpt.lists.illiana.net>
List-Unsubscribe: <http://lists.illiana.net/mailman/listinfo/app_rpt&gt;,&lt;mailto:app\_rpt\-request@lists\.illiana\.net?subject=unsubscribe&gt;
List-Archive: <http://lists.illiana.net/pipermail/app_rpt&gt;
List-Post: <mailto:app_rpt@lists.illiana.net>
List-Help: <mailto:app_rpt-request@lists.illiana.net?subject=help>
List-Subscribe: <http://lists.illiana.net/mailman/listinfo/app_rpt&gt;,&lt;mailto:app\_rpt\-request@lists\.illiana\.net?subject=subscribe&gt;
Errors-To: app_rpt-bounces@lists.illiana.net
X-OriginalArrivalTime: 04 Nov 2006 17:05:40.0075 (UTC) FILETIME=[7478BBB0:01C70033]
-Send out DTMF
-Pause
-Send out more DTMF
-Pause
Gary K6HN
and.. a 'p' or a 'P' in a macro gives you a 500ms pause.
MIME-Version: 1.0
Precedence: list
-Send out DTMF
-Pause
-Send out more DTMF
-Pause
Gary K6HN
Cool, I didn't realize Macros could be assigned as multiple digits.
Gary
Sent: Saturday, November 04, 2006 1:05 PM
Subject: Re: [App_rpt] Macro's and DTMF
you can have
more.
>From: "Gary Young" <pcfrover@tcomeng.com>
>MIME-Version: 1.0
17:05:37 -0000
0 with SMTP; 4
17:05:33 -0000
with SMTP; 4 Nov
>2006 17:05:33 -0000
>Received: from den
>2006 17:05:32 +0000
>Precedence: list
>List-Unsubscribe:
pp_rpt-request@lists.illiana.net?subject=unsubscribe>
>List-Subscribe:
pp_rpt-request@lists.illiana.net?subject=subscribe>
system Macro?
>-Send out DTMF
>-Pause
>-Send out more DTMF
>-Pause
>Gary K6HN
>_______________________________________________
Perfect!
Gary
Sent: Saturday, November 04, 2006 1:12 PM
I can't get multi digit macros to work.
This doesn't work.
[functions-repeater]
5=macro
[macro]
12=*12001
Sending DTMF *512 does nothing.
Gary
you can have
more.
>MIME-Version: 1.0
17:05:37 -0000
0 with SMTP; 4
17:05:33 -0000
with SMTP; 4 Nov
>2006 17:05:33 -0000
>Received: from den
>2006 17:05:32 +0000
>Precedence: list
>List-Unsubscribe:
>List-Subscribe:
system Macro?
>-Send out DTMF
>-Pause
>-Send out more DTMF
>-Pause
>Gary K6HN
This didn't work for me. Can you send an example?
Gary
you can have
more.
