Mike
1
I am tracing down a issue and I need a copy of /etc/dahdi/system.conf
If anyone could post the contents of that file, I might kiss you (don’t count on it)
My old backups do not include that.
Thanks in advance
N8PC
2
DAHDI Configuration File
This file is parsed by the DAHDI Configurator, dahdi_cfg
Span Configuration
First come the span definitions, in the format
span=,,<line build out (LBO)>,,[,yellow]
All T1/E1/BRI spans generate a clock signal on their transmit side. The
parameter determines whether the clock signal from the far
end of the T1/E1/BRI is used as the master source of clock timing. If it is, our
own clock will synchronise to it. T1/E1/BRI connected directly or indirectly to
a PSTN provider (telco) should generally be the first choice to sync to. The
PSTN will never be a slave to you. You must be a slave to it.
Choose 1 to make the equipment at the far end of the E1/T1/BRI link the preferred
source of the master clock. Choose 2 to make it the second choice for the master
clock, if the first choice port fails (the far end dies, a cable breaks, or
whatever). Choose 3 to make a port the third choice, and so on. If you have, say,
2 ports connected to the PSTN, mark those as 1 and 2. The number used for each
port should be different.
If you choose 0, the port will never be used as a source of timing. This is
appropriate when you know the far end should always be a slave to you. If
the port is connected to a channel bank, for example, you should always be
its master. Likewise, BRI TE ports should always be configured as a slave.
Any number of ports can be marked as 0.
Incorrect timing sync may cause clicks/noise in the audio, poor quality or failed
faxes, unreliable modem operation, and is a general all round bad thing.
NOTE: The B410P card cannot reliably connect one of its four ports
configured in TE mode to another one configured in NT mode. It will not
reliably sync clock from itself. Please use another physical card and
configure one to provide clock and one to recover clock in any B410P test
environments.
The line build-out (or LBO) is an integer, from the following table:
0: 0 db (CSU) / 0-133 feet (DSX-1)
1: 133-266 feet (DSX-1)
2: 266-399 feet (DSX-1)
3: 399-533 feet (DSX-1)
4: 533-655 feet (DSX-1)
5: -7.5db (CSU)
6: -15db (CSU)
7: -22.5db (CSU)
If the span is a BRI port the line build-out is not used and should be set
to 0.
framing::
one of ‘d4’ or ‘esf’ for T1 or ‘cas’ or ‘ccs’ for E1. Use ‘ccs’ for BRI.
‘d4’ could be referred to as ‘sf’ or ‘superframe’
coding::
one of ‘ami’ or ‘b8zs’ for T1 or ‘ami’ or ‘hdb3’ for E1. Use ‘ami’ for
BRI.
* For E1 there is the optional keyword ‘crc4’ to enable CRC4 checking.
* If the keyword ‘yellow’ follows, yellow alarm is transmitted when no
channels are open.
#span=1,0,0,esf,b8zs
#span=2,1,0,esf,b8zs
#span=3,0,0,ccs,hdb3,crc4
Dynamic Spans
Next come the dynamic span definitions, in the form:
dynamic=,,,
Where is the name of the driver (e.g. eth), is the
driver specific address (like a MAC for eth), is the number
of channels, and is a timing priority, like for a normal span.
use “0” to not use this as a timing source, or prioritize them as
primary, secondard, etc. Note that you MUST have a REAL DAHDI device
if you are not using external timing.
dynamic=eth,eth0/00:02:b3:35:43:9c,24,0
If a non-zero timing value is used, as above, only the last span should
have the non-zero value.
Channel Configuration
Next come the definitions for using the channels. The format is:
Valid devices are:
e&m::
Channel(s) are signalled using E&M signalling on a T1 line.
Specific implementation, such as Immediate, Wink, or Feature
Group D are handled by the userspace library.
e&me1::
Channel(s) are signalled using E&M signalling on an E1 line.
fxsls::
Channel(s) are signalled using FXS Loopstart protocol.
fxsgs::
Channel(s) are signalled using FXS Groundstart protocol.
fxsks::
Channel(s) are signalled using FXS Koolstart protocol.
fxols::
Channel(s) are signalled using FXO Loopstart protocol.
fxogs::
Channel(s) are signalled using FXO Groundstart protocol.
fxoks::
Channel(s) are signalled using FXO Koolstart protocol.
sf::
Channel(s) are signalled using in-band single freq tone.
Syntax as follows:
channel# => sf:,,,,,
rxfreq is rx tone freq in Hz, rxbw is rx notch (and decode)
bandwith in hz (typically 10.0), rxflag is either ‘normal’ or
‘inverted’, txfreq is tx tone freq in hz, txlevel is tx tone
level in dbm, txflag is either ‘normal’ or ‘inverted’. Set
rxfreq or txfreq to 0.0 if that tone is not desired.
unused::
No signalling is performed, each channel in the list remains idle
clear::
Channel(s) are bundled into a single span. No conversion or
signalling is performed, and raw data is available on the master.
bchan::
Like ‘clear’ except all channels are treated individually and
are not bundled. ‘inclear’ is an alias for this.
rawhdlc::
The DAHDI driver performs HDLC encoding and decoding on the
bundle, and the resulting data is communicated via the master
device.
dchan::
bundle and also performs incoming and outgoing FCS insertion
and verification. ‘fcshdlc’ is an alias for this.
hardhdlc::
The hardware driver performs HDLC encoding and decoding on the
and verification. Is subject to limitations and support of underlying
hardware. BRI spans serviced by the wcb4xxp driver must use hardhdlc
channels for the signalling channels.
nethdlc::
The DAHDI driver bundles the channels together into an
hdlc network device, which in turn can be configured with
sethdlc (available separately). In 2.6.x kernels you can also optionally
pass the name for the network interface after the channel list.
Syntax:
nethdlc=[:interface name]
Use original names, don’t use the names which have been already registered
in system e.g eth.
dacs::
The DAHDI driver cross connects the channels starting at
the channel number listed at the end, after a colon
dacsrbs::
the channel number listed at the end, after a colon and
also performs the DACSing of RBS bits
The channel list is a comma-separated list of channels or ranges, for
example:
1,3,5 (channels one, three, and five)
16-23, 29 (channels 16 through 23, as well as channel 29)
So, some complete examples are:
e&m=1-12
nethdlc=13-24
fxsls=25,26,27,28
fxols=29-32
An example of BRI port:
span=1,1,0,ccs,ami
bchan=1,2
hardhdlc=3
NOTE: When using BRI channels in asterisk, use the bri_cpe, bri_net, or
bri_cpe_ptmp (for point to multipoint mode). libpri does not currently
support point to multipoint when in NT mode. Otherwise, the bearer channel
are configured identically to other DAHDI channels.
#fxoks=1-24
#bchan=25-47
#dchan=48
#fxols=1-12
#fxols=13-24
#e&m=25-29
#nethdlc=30-33
#clear=44
#clear=45
#clear=46
#clear=47
#fcshdlc=48
#dacs=1-24:48
#dacsrbs=1-24:48
Tone Zone Data
Finally, you can preload some tone zones, to prevent them from getting
overwritten by other users (if you allow non-root users to open /dev/dahdi/*
interfaces anyway. Also this means they won’t have to be loaded at runtime.
The format is “loadzone=” where the zone is a two letter country code.
You may also specify a default zone with “defaultzone=” where zone
An up-to-date list of the zones can be found in the file zonedata.c
loadzone = us
#loadzone = us-old
#loadzone=gr
#loadzone=it
#loadzone=fr
#loadzone=de
#loadzone=uk
#loadzone=fi
#loadzone=jp
#loadzone=sp
#loadzone=no
#loadzone=hu
#loadzone=lt
#loadzone=pl
defaultzone=us
PCI Radio Interface
The PCI Radio Interface card interfaces up to 4 two-way radios (either
a base/mobile radio or repeater system) to DAHDI channels. The driver
may work either independent of an application, or with it, through
the driver;s ioctl() interface. This file gives you access to specify
load-time parameters for Radio channels, so that the driver may run
by itself, and just act like a generic DAHDI radio interface.
Unlike the rest of this file, you specify a block of parameters, and
then the channel(s) to which they apply. CTCSS is specified as a frequency
in tenths of hertz, for example 131.8 HZ is specified as 1318. DCS
for receive is specified as the code directly, for example 223. DCS for
transmit is specified as D and then the code, for example D223.
The hardware supports a “community” CTCSS decoder system that has
arbitrary transmit CTCSS or DCS codes associated with them, unlike
traditional “community” systems that encode the same tone they decode.
this example is a single tone DCS transmit and receive
specify the transmit tone (in DCS mode this stays constant):
#tx=D371
specify the receive DCS code:
#dcsrx=223
this example is a “community” CTCSS (if you only want a single tone, then
only specify 1 in the ctcss list)
specify the default transmit tone (when not receiving):
#tx=1000
Specify the receive freq, the tag (use 0 if none), and the transmit code.
The tag may be used by applications to determine classification of tones.
The tones are to be specified in order of presedence, most important first.
Currently, 15 tones may be specified…
#ctcss=1318,1,1318
#ctcss=1862,1,1862
The following parameters may be omitted if their default value is acceptible
Set the receive debounce time in milliseconds:
#debouncetime=123
set the transmit quiet dropoff burst time in milliseconds:
#bursttime=234
set the COR level threshold (specified in tenths of millivolts)
valid values are {3125,6250,9375,12500,15625,18750,21875,25000}
#corthresh=12500
Invert COR signal {y,n}
#invertcor=y
Set the external tone mode; yes, no, internal {y,n,i}
#exttone=y
Now apply the configuration to the specified channels:
We are all done with our channel parameters, so now we specify what
channels they apply to
#channels=1-4
Overiding PCM encoding
Usually the channel driver sets the encoding of the PCM for the
channel (mulaw / alaw. That is: g711u or g711a). However there are
some cases where you would like to override that. ‘mulaw’ and ‘alaw’
set different such encoding. Use them for channels you have already
defined with e.g. ‘bchan’ or ‘fxoks’.
#mulaw=1-4
#alaw=1-4
‘deflaw’ is similar, but resets the encoding to the channel driver’s
default. It must be useful for something, I guess.
#mulaw=1-10
#deflaw=5
Echo Cancellers
DAHDI uses modular echo cancellers that are configured per channel. The echo
cancellers are compiled and installed as part of the dahdi-linux package.
You can specify in this file the echo canceller to be used for each
channel. The default behavior is for there to be NO echo canceller on any
channel, so it is very important that you specify one here.
Valid echo cancellers are: hwec, mg2, kb1, sec2, and sec.
‘hwec’ is a special echo canceller that should be used if hardware echo
cancellation is desired on and available on the specified channels.
If compiled, ‘hpec’ is also a valid echo canceller.
To configure the default echo cancellers, use the format:
echocanceller=,<channel(s)>
Example:
Configure channels 1 through 8 to use the mg2 echo canceller
#echocanceller=mg2,1-8
And change channel 2 to use the kb1 echo canceller.
#echocanceller=kb1,2
I have ACID running on node 28599 but no dahdi, sorry. I don’t think dahdi was around when ACID was out
GeorgeC W2DB
